howardmoon
I've been using a GT-AX6000 with T-Mobile gateway successfully for months, but AT&T fiber just became available so I leapt. It seems to work except for some sites that require authentication (guessing) like Netflix, Sling, Plex and even on AT&T's site that require logging in. When using their WiFi and my LAN disconnected, all is well.
My home subnet is 192.168.1.x which is what the AT&T uses, so the tech and I changed it's ip to 192.168.2.254 along with the DHCP pool 3rd octets.
What do I need to change on my router? I've changed some things but the permutations are overwhelming.
192.168.1.1
WAN Connection Type Automatic IP
Enable WAN, NAT Yes
Enable UPnP IGD & PCP/NAT-PMP No
Default status : Get the DNS IP from your ISP automatically.
tried Googles and some combos
Enable DNS Rebind protection No
Enable DNSSEC support No
Prevent client auto DoH Auto
DNS Privacy Protocol None
Static Routes none
Enable the DHCP Server Yes
Hide DHCP/RA queries No
GT-AX6000's Domain Name local
IP Pool 192.168.1.100 - 254
192.168.1.1
Enable WAN, NAT Yes
Static Routes none
