Hello,
Almost always after a router reboot (but not 100% always), the [bcmsw_rx] process will consistently run at 100% CPU during my hardwired VPN speed tests with resulting download speeds at ~120 Mbps.
The unexpectedly high CPU usage at 100% is what I am concerned about along with the significant reduction in VPN throughput that is apparently a result of that. This issue does not resolve itself with time.
If I restart the OpenVPN client, [bcmsw_rx] will then consistently behave normally with resulting VPN download speeds between 180 to 200 Mbps.
What could be causing these observations?
Tested only on:
RT-AX88U with Asuswrt-Merlin 386.1, 386.2, 386.2_2
PIA VPN with AES-128-GCM
Cox Gigablast
Speedtest.net Mac desktop clients
In both situations above, non-VPN speed tests show [bcmsw_rx] at ~50% with no throughput degradation.
And the log file (attached) does not show any differences in the OpenVPN statements between the router reboot and the OpenVPN client restart sequences.
Tested only on:
Cox Gigablast
