Processes from Entware using UTC instead of local time
microlah
Hi everyone. Currently I have using the AC86U router with the latest 378.54_2 firmware. I have installed a couple of packages from Entware. However I noticed a problem where all the processes from Entware are using UTC instead of local time (UTC+8) when logging on the system log page, as highlighted below in red. I am wondering if it is possible to change the behaviour so that everything would use local time consistently.
Try the following
1. Install appropriate zoneinfo. For Europe
opkg install zoneinfo-europe
2. Create a symlink to your zone. For Paris
ln -sf /opt/share/zoneinfo/Europe/Paris /etc/localtime
3. Check if it helps.
4. Create a script in /opt/etc/init.d to make a symlink at boot
