Project: Block ads for all network users...
OzarkEdge
Part of the Furniture
There has to be a lot of ad-blocking experience here... I have none and would appreciate some basic advice to get me started in the right direction. How should I go about blocking ads for all network users... desktop, mobile, TV devices(?)? My preference is to not integrate too many functions into one box so that managing one does not involve the other, if that's an option. I currently use Quad9 DoT.
OE
As you don't run Merlin firmware, if you run a server at home or an RPi I'd suggest Pi-hole with Steven Black's Diversion blocklist.
Try AdGuard with DoT. I remember Asuswrt has presets for it.
OK, I'll test this path of least resistance...
AdGuard Public DNS
Option 2: Configure AdGuard DNS manually
Routers
Default servers
AdGuard DNS will block ads and trackers.
IPv4:
94.140.14.14
94.140.15.15
Our server addresses
DNS-over-TLS
Default server
tls://dns.adguard-dns.com
My ASUSWRT WAN DNS and DoT configuration
https://www.dnscheck.tools/ results
Per some previous DoT example, I'm omitting tls:// from the TLS Hostname(?)
OE
Your settings are correct. The router itself can use different DNS servers, your ISP default for example. There is no ads and trackers to block in what the router needs to resolve for NTP, Trend Micro updates and data sharing, Asus update servers, etc. If something the router needs gets flagged by mistake and filtered upstream - may cause tricky to diagnose issue.
Some of your clients may still show ads. DHCP offers DNS servers to clients, but they are not mandatory. Clients with own DNS settings will go around. Stock Asuswrt doesn't have DNS interception and redirection in GUI. If you want to experiment - here.
Simplest method is setting the router to use an ad filtering DNS, like AdGuard. If you want to get more fancy, then having either a Pi or a VM/Docker running Pihole is a great option. Most NAS platforms allow you to install a docker image of Pihole, if you have such a NAS.
OzarkEdge Solved Project: Block Windows program from phoning home... General Network Security 3
