Protected Management Frames default?
netmik3
Can someone show me the wireless screen? What's the default for Protected Management Frames from the factory? I have the ax11000.
Your reply disappeared but yes I want Merlin default of course. I forgot the setting when I played with WPA3 but I'm going back. I'm getting all kinds of disconnects. I set it to disabled.
Sorry, I deleted my reply because I confused PMF with Airtime Fairness.
PMF is typically disabled with WPA2, enabled with WPA3 (which makes it mandatory).
So this is Merlin default for all 3 radios right?
Disabled by default under WPA2, same as on stock. It will automatically be enabled if you select WPA3 however.
