JT Strickland
RT-AC86U 384.16 B3, RT-AC68U aimesh node w/ 384.16, Diversion, uiDivstats, Skynet, AiProtection, Scribe, uiScribe, Conmon, spdMerlin, scMerlin, Nsrum, 250/10 broadband with Netgear CM-1000 docsis 3.1 modem.
I couldn't log into my router this morning, like it was froze up. I switched it and the modem off then back on, then had a lot of these in the log:
Apr 13 09:52:30 RT-AC86U-8F38 kernel: br0: received packet on eth3 with own address as source address
And this is what was in the skynet log, and quite a few of them:
Apr 13 07:58:38 RT-AC86U-8F38 Skynet: [*] Private WAN IP Detected 192.168.100.10 - Please Put Your Modem In Bridge Mode / Disable CG-NAT
We had some strong storms yesterday, and the power and cable internet was off for a few hours.
I found a post on the dd-wrt board doing a search, and they said they resolved the first issue by changing the MAC address for eth3 and w1.1 in the Port Setup of the bridging section, and it worked like a charm. It may be the power outage that brought it on, but I have had the "own address" error for a while, just not near as many in a row.
Can anyone confirm this is what needs doing, and how do I go about doing it? Can my ISP put the modem in Bridge Mode and disable CG-NAT? Also, is changing the MAC address something I can do, or should I get someone to do it? It has also been eth5 in the past, now eth3, so I don't know. I could sure use some guidance.
TIA,
jts
TIA,
jts
