MarvinAndro
I'm not sold on upgrading from my current RT-AC68U to the RT-AC5300 but got an open box one for "cheaper" and thought I'd give it a try. And I did staring at 1am last night, so probably my failure is due to lack of sleep and not finding the right entry in this forum.
Here's what I did:
1) ran the latest (nvram-save-r24a) scripts on the AC68U while the AC5300 was booting up for the first time with my laptop plugged into one of the LAN ports
2) I could login fine to 192.168.1.1 and go through the steps to say No to all settings, i.e. skipping as much as possible from the Setup Wizard (it asked me tons of times if I really wanted to leave the 3 WiFi channels open!)
3) as soon as I could get to the Firmware page, I selected RT-AC5300_380.66_4.trx and hit the flash button.
4) it took its time and said I had to reboot manually. I recall something about best way to do it was to power off and on; so I did that.
5) 10 mins later I still couldn't ping 192.168.1.1 although at some points before (had `ping -t` running), it was apparently responding. As far as I recall, the 3 most-left LEDs were steady green, power and WiFi 2+5 but I could not see WiFi broadcasted to connect to.
6) My past experience is that sometimes you need to reboot a few times before things settle. Surprisingly the next 2-3 reboots ended up with different LEDs on, anywhere from just the Power one, to almost all of them with the Internet one staying solid red.
7) Past 2am and I did grab the Asus Firmware Restoration tool, pointed it to RT-AC5300_3.0.0.4_380_7627-gb433db3.trx, hit the Reset with a paper clip until the power LED started blinking. At that time I could again see ping replies from 192.168.1.1 so I hit the Upload button. Thought the open box router might have been a demo for too long and the firmware was too old to jump directly to Asuswrt-Merlin.
8) After about 5 minutes the router rebooted and my browser opened the standard router.asus.com page, asking me to run the Setup Wizard.
9) Again, everything worked fine as in Step 2), I was back to square one, but on the latest original firmware.
10) Again, step 3, pushed RT-AC5300_380.66_4.trx and got the same experience - it won't boot up properly, not once, not twice.... gave up after a few more power off/on and let it run like this, hoping some magic will finish while I sleep.
This morning I was back to the 3 LEDs like in Step 5 above. Did a few searches in this forums, on the web in general, mainly looking for "signed version of firmware" that perhaps I needed to flash first before jumping to Merlin's 380.66_4, any specific 30/30/30 reset that I should do..... and here I am, asking for help.... or a confirmation that I have to run back to the store and tell them they gave me a half-brick.
At the time of typing this, I've hit the Firmware Restoration tool one more time and pushed RT-AC5300_3.0.0.4_380_7743-g2cf84e9.trx (the last-1 version from ASUS' site). It flashed fine, I've setup now the 3 channels and I'm playing with the new settings (those I didn't have on the AC68U) while I'm not connected to the WAN, nor do I have any clients on this router, apart from the LAN attached laptop but everything appears to be working fine.
I flashed my first Asuswrt-Merlin on the AC68U many years ago and don't recall doing an extra step but....
Can anyone point me to the missing step?
Thanks a lot!
Here's what I did:
Thanks a lot!
