I'm trying to get a good reliable coverage over a large setup (inside and outside), the house is two stories with solid concrete floors and double brick walls. So far my setup is:
1 x AC68U: Main Router located in the "Main" part of the house covering the main part of the lower floor. Running 274_4422 Asus
2 x AC66U: AP Mode (connected via Gigabyte to the main switch), one is in the ceiling to cover the top floor, and one under the deck to cover the outside and the end of the lower floor. Both are running 374.39 Merlin
All have the same SSID, and Password. I'm using 80mW for both 2.4 and 5GHz frequency. Bands being used are 149/153/157 on 5GHz, and 1/6/11 on 2.4GHz. As we are on a big block, there is no interference from any neighbours on the 5GHz band and only weak signals on the 2.4Ghz band.
It all works pretty well but I have a couple of Questions:
1) Roaming: Most of my devices (Andriod, iPhones, PCs) will not "roam" between the AP's and will only grab the stronger signal if you power cycle them. From what I've read, this is "normal" for many consumer devices but????
2) Any setting tweaks to improve the range (esp 5ghz)?
Nathan
Nathan
