sfx2000
Part of the Furniture
Check the releases notes and upgrade if needed... login to the QNAP, and the update should be there to download...
Virtualization Station 1.4.3366
( 2015/05/29 )
[Improvements]
l Supports remote export of virtual machines (VM)
l Added new overview page layout
l Added support for USB 3.0 in VM
l Divided ports configuration into Port Settings and UPnP Settings
l Fixed security issue - VENOM: QEMU vulnerability (CVE-2015-3456)
l Instead of selecting VMs in the QVM Setting, you can setup VM as QVM in the overview page
[Bug Fixes]
l Fixed bug - Displays the message: “The port 8088 / 8089 has been used by other applications. Please disable those applications and restart Virtualization Station again” when launching the Virtualization Station using QTS version 4.1.4
l Fixed bug - Displays the string: “Missing” on the VM network
l Fixed bug - Displays the message: “cannot get interface MTU on bra” when starting the VM
l Fixed bug - Cannot click “Restart” and “Apply” in Network Settings
l Fixed bug - Cannot export VM with the error message “File check failed”
[Note]
l If the NAS uses QTS 4.1.4 and displays the message “The port 8088 / 8089 has been used by other applications….” when launching Virtualization Station, then please update to the latest version of Virtualization Station.
[Limitations]
l Due to the security fix (CVE-2015-3456) every VM needs to be shutdown before upgrading this version.
l USB 3.0 is only available for Windows 8 or above, CentOS 7 or above, Fedora 16 or above, RHEL 7 or above and Ubuntu 14.04 or above.
l This version is only available for QTS versions 4.1.x.
( 2015/05/29 )
[Improvements]
[Bug Fixes]
[Note]
[Limitations]
