tsunami2311
So i looking to replace my AC66U
Correct me if I am wrong HW accl/CF are same thing? or 2 diffrent things? I know traditinal QOS turns off HW acceleration and so does PER ip monitor.
Does Bandwithlimiting to? cause it say CF ( hw/accl?) is on in "http://192.168.1.1/Advanced_SwitchCtrl_Content.asp" page when used with out PER ip monitor?,
Does Apdative QOS turn off HW acceleration?
I looking to get RT3100 ( 4port) cause it the cheaper of the 1.4ghz dual core cpu routers from asus. And I will be using QOS be it limiter/adaptive IF that does turn off hw accler/cf I need to make sure router can do 300+mbit.
http://demoui.asus.com/
i am assuming this same ui 3100 uses for most part? it missing some pages like "http://192.168.1.1/Tools_Sysinfo.asp" or is that part of merlinfw?
