Lethasniper007
How does the QOS perform on the asus RT-AC66U does it Realy worrk especially for gaming or should I look else where ? there are some other routers that have qos but are Realy bad
can anyone on here help me out with QosHow would I setup the QOS im new to all this kind of stuff. I can tell u my setup its 2 Xbox 360 which we want more bandwith how do I setup that ? Do I just enable QOS box and that's all?
if Qos only works for upload then why is ther a download section on qos what is the purpose of that?QoS on Asus routers only limits the upload speed, (from memory).
The newest QoS in the RT-AC87U is a different implementation of QoS for Asus routers and should respect both up and down limits you choose.
Asuswrt will always provide full bandwidth to a connection unless something with a higher priority also runs. That means your torrent will run at full speed, until you start streaming a video, at which point the torrent will drop down in speed.
I haven't tested this in years on the older routers, but it was working beautifully when I tested it with Adaptive QoS on the RT-AC87U. Running a speedtest was at full speed, and when it stopped the concurrent torrent went back to nearly filling my line.
If that is the case, why when QOS is enabled, and I test using speednet or similar, can i not hit full speeds?
Welcome To SNBForums
