QOS Settings Question for a QOS Guru
krum
RT-AC66u
I ran across this while trying different options with QOS;
I am trying to have 2 games that my kids play be lag free, while others are downloading HTTP 80. The games that are currently being played are WOW and LOL.
I read this and wondering it this really works.
Set up the Upload rate limit
There are two columns of upload bandwidth, Minimum reserved bandwidth and maximum bandwidth limit.
Minimum reserved bandwidth means that the QoS reserved bandwidth for specific priority when the upload bandwidth is not enough.
For example, the value 80 of highest priority is that QoS reserves 80% of upload bandwidth for the highest priority.
Maximum bandwidth limit means the maximum bandwidth which specific priority can use.
For example, the value 95 of lowest priority is that the lowest priority application can only use the 95% of bandwidth even there are no any other application use the network.
The current settings is automatically changed after filling the upload and download bandwidth.
Set up the Download Bandwidth
The value 0 means that there is no limit for download bandwidth.
Generally speaking, it is unnecessary to set the download bandwidth limit because the download priority is depends on the upload packet priority.
