qos-start script not executed after reboot/QOS activation
Tamagnun
Hi everybody,
with the latest fw versions (at least since 378.56_2 release) the /jffs/scripts/qos-start script is not automatically executed when the router is restarted or QOS activated.
In the script I've written for my Asus RT-AC56U I added the following tc command in order to limit the download rate in input from WAN interface:
tc filter add dev eth0 parent ffff: protocol ip prio 50 u32 match ip src \
0.0.0.0/0 police rate 2400kbit burst 192k drop flowid :1 >>$LOGFILE 2>&1
but the download bandwidth is limited only if I start manually the script, otherwise the full bandwidth is available.
Has somebody else set a qos-start script and is experiencing the same issue?
Thank you for any answer
Regards
Roberto
Check your system log to confirm that the script does get started or not.
Make sure you added a shebang at the start of your script, and that it's executable.
