QoS w/ Load Balance
shoe
Posted a month ago about load balance functionality and can say it works pretty well, at least at 1:1 with 2 6/2mbps connections (Satellite).
But my main question right now is the bandwidth setting on 374.40 (N66U), should I set the overall bandwidth to 12/4 or leave it at 6/2? Am not sure how QoS is played with load balance.
well, i would try both, and run speed tests with both, see the results.
another good idea if your trying to avoid congestion would be speedtesting and running a constant ping to something reliable like google.com, if QOS does its job good, your ping should not increase much, if your ping is going up alot, it kinda defeats the purpose of QOS right?
