QTS 4.2.0 Build 1023 update - Intel/ARM
sfx2000
Part of the Furniture
It is a reboot...
QTS4.2.0 Build 1023
[Bug Fixes]
- Fixed an issue where administrator group users could not access Download Station after updating to 4.2.0.
- Fixed an issue where users could not upload files when sharing folders and sharing transcoded videos are enabled.
- Fixed an issue where the wizard for creating RTRR backup jobs that backup to remote Windows via CIFS/SMB would fail during testing.
- Access rights will no longer be reset to default when unplugging and then plugging in a USB storage device.
- Fixed an issue where the refresh icon keeps running on the Percent Used column after creating an iSCSI LUN.
- Fixed an issue where after installing the app domotz the Storage Manager Volume-LUN status is always showing the loading icon.
- Fixed an issue where a Thin Volume would occasionally report that it is being formatted.
- The Epson AcuLaser MX14 printer now works for the TS-563.
- Fixed an issue where the NAS would freeze due to some apps being unable to check for external resources (such as external IP addresses).
- Fixed an issue where users could get stuck attempting to log in to QTS due to an incorrect settings file.
- Fixed an issue where users cannot enable trusted domains in the Network Service after upgrading to QTS 4.2.0.
- Improved the stability of Download Station when using Magnet Links to download files on ARM-based NAS models.
I wish they would fix the issue on each firmware update, Download station gets installed, I don't need it or want it. Grrr.
