sfx2000
Part of the Furniture
QTS 4.2.2 Build 20161021
[Known issue]
Back up
- The Container Station folder can only be backed up using Rsync when no containers are running. It is recommended to use the import/export feature in Container Station to back up containers.
Container Station
- Setup default folder of Contrainer Station on a VJBOD shared folder and reboot VJBOD would cause Container Station crash. Container Station v1.6 will not support VJBOD and filter out all VJBOD shared folders.
[Bug fixes]
- Fixed an issue where the system logs would display error messages and users could not upload Intermediate Certificate.
- Fixed an issue where users could not access folders via SMB even with permission.
- Fixed an issue where users could not connect to the NAS or the Internet via VPN server when Port Trunking was enabled.
- Fixed an issue where the health status of some disks would be erroneously reported as abnormal after a firmware update.
- Fixed an issue where the default gateway would revert to earlier settings after rebooting.
- Fixed an issue where an error message would appear when users logged in with a myQNAPcloud account after setting the default gateway as the uplink in Switch Mode.
- Fixed an issue where the NAS could not connect to Windows Server 2008 R2 and create a backup job for an iSCSI LUN.
- Fixed an issue where the user interface would freeze when users configured network settings after blocking ports on their router.
- Fixed an issue where Backup Station could not replicate a large number of files from a remote server to a local NAS via RTRR.
- Fixed an issue where the temperature of mSATA SSDs would exceed their threshold after S.M.A.R.T. testing.
- Fixed an issue where users were unable to access folders via SMB even with permission.
- Fixed an issue where the system volume could not revert to snapshots due to failing to unmount the volume.
- Fixed an issue where the ACL permissions of files would disappear after reverting to a snapshot.
[Known issue]
Back up
Container Station
[Bug fixes]
