sfx2000
Part of the Furniture
QTS 4.3
QTS 4.3.3.0188 Build 20170516
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- When QTS 4.3.x is installed on NAS models running on 64-bit Intel and AMD processors, some applications may not be supported. To check if installed apps on your NAS are compatible with QTS 4.3.x, download the QTS 64-bit compatibility tool and install it on your current QTS build. (https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
- QTS 4.3.x is the final available firmware update for the following models:
TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Enhancements]
Added support for the USB 3.1 PCIe card USB-U31A2P01 on the following NAS models: TVS-463/663/863/863+, TS-563, TS-463U/863U/1263U, TVS-471/671/871, TVS-471U/671U/871U, TVS-682/882/1282, TVS-682T/882/1282T, and TES-1885U/3085U.
[Fixes]
- The NAS does not run out of memory when using thin volumes (or LUNs) and space reclamation on QTS 4.3.x.
- Users can successfully copy files from Promise DAS devices to the NAS using AFP via Thunderbolt.
- The "Snapshot management" option is correctly displayed on the "More" menu of the volumes on the left pane on File Station.
- Users can successfully edit WebDAV connections and save the changes on File Station.
- Apache daemon can successfully start when the Web Server service is enabled.
- Users can upload files that have filenames beginning with "._" to shared folders via SMB.
[Other Changes]
- After updating the NAS managed by Q'center from 4.2.x to 4.3.x, the administrator of Q'center must input the password of each NAS to continue monitoring.
- Twonky Server is no longer supported. Use the DLNA Media Server built into QTS as your DLNA server.
- Download Station
Users can now be notified when downloads complete (instead of when download tasks complete).
- Virtualization Station
Due to advancements in the backup features, virtual machines created in older versions (1.x/2.x) of Virtualization Station can no longer be backed up and restored in 3.0. (A workaround is to clone an older Virtual Machine; the cloned VM can be backed up/restored, but all original snapshots will be removed)
[Important Notes]
[Enhancements]
[Fixes]
[Other Changes]
- Download Station
