sfx2000
Part of the Furniture
QTS 4.3.3.0361 Build 20171101
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- When QTS 4.3.x is installed on NAS models running on 64-bit Intel and AMD processors, some applications may not be supported. To check if installed apps on your NAS are compatible with QTS 4.3.x, download the QTS 64-bit compatibility tool and install it on your current QTS build. (https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
- QTS 4.3.3 is the final available firmware update for the following models:
TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Fixed Issues]
- Fixed multiple vulnerabilities in WPA2 to prevent the exposure of sensitive information via Wi-Fi networks (CVE-2017-13077, CVE-2017-13078, CVE-2017-13079, CVE-2017-13080, CVE-2017-13081, CVE-2017-13082, CVE-2017-13084, CVE-2017-13086, CVE-2017-13087, CVE-2017-13088).
- Fixed a vulnerability in the Linux kernel (CVE-2017-1000253).
- NAS-to-NAS backup jobs sometimes would fail due to unexpected errors on certain ARM models.
- HD Player would not be correctly displayed when users accessed HybridDesk Station on a browser via Remote Desktop.
- It would take a long time to delete multiple user accounts after granting them permissions to access a large number of files.
- Control Panel could not correctly display the DNS tree structure after users installed Python 2.7.12.
- Media Library would keep indexing files after users uploaded .flac files to the NAS.
- The USB LED on the NAS would keep blinking after users ejected a Transcend JetFlash USB drive.
- Users would encounter unexpected formatting errors when sending emails using IIS 6.0 as the SMTP server.
- Local user accounts could not share the same usernames with domain user accounts.
- Owners of shared folders could not access their folders when their access were denied in advanced folder permission settings.
- Syslog Viewer would display incorrect facility names.
- Users could not upload files larger than 2 GB to the TS-x31 series.
- Domain users could not access shared folders via FTP where they were granted access permissions.
- Special symbols in file names would be converted inconsistently when users uploaded files to the NAS via both AFP and SMB.
- System Connection Logs would display the connection type as HTTP when users accessed Download Station via HTTPS.
- Users could not select a volume to analyze in "Diagnostic Tool" > "File System Analyzer" on the TS-220.
[Important Notes]
[Fixed Issues]
