Question about RT-AX58U firmware and Aimesh
apvm
I wanted to use a RT-AX58U as a Aimesh node, its firmware is 384, I tried to upgrade its firmware to 388 with Asus firmware, it can't. At the end I used Merlin firmware to upgrade and it suceed. Wondering why? Thanks.
There was a minimum 386 version required to update forward, but now removed by Asus since another 388 version was made minimum required. For Asuswrt you have to use Recovery for this jump in firmware version. Asuswrt-Merlin perhaps doesn't make minimum required firmware checks before flashing. You have missed years of firmware upgrades...
Thank you so much, so I am alright now no need to do Recovery and I can either flash Asuswrt or Asuswrt-Merlin without problem?
Another problem, I can not flash Asuswrt to the latest 388 Asuswrt-Merlin firmware that I flashed to the router. Anyway, as long as Aimesh will work fine with the main mesh router with Asuswrt firmware, I should be fine.
Sorry, no idea what your main router is. Stock Asuswrt - Recovery.
Thanks for your 1st reply about recovery software, I just finished and flashed it to the lastest Asus firmware. My main Aimesh router is not supported by Merlin so I think I better have this RT-AX58U back to Asus firmware, thanks again.
