Hello everyone,
Ill like to access to the vlan 630 over the wifi, i want to use my phone mobile as a client.How can i do it?
This is my actual config
admin@RT-AC68U-0CB8:/tmp/home/root# robocfg show
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 00:00:5e:00:01:2b
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 94:c6:91:17:98:d7
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: e4:8d:8c:bb:23:fe
Port 3: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 4: 10HD enabled stp: none vlan: 57974 jumbo: off mac: 00:25:9b:6e:81:85
Port 5: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 4c:ed:fb:a5:0c:b8
Port 7: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 5t
2: vlan2: 0 5
603: vlan603: 0t 5t
630: vlan630: 0t 4
The vlan 603 is for internet and the 630 is for Voip, the port 4 is connected to a linksys pap2. The linksys is working fine, but when i try to logging with the phone over the wifi i cant.Even i cant logging with any computer over a cable, the vlan 630 is only for the port 4 how can i share it?
Thanks a lot.
Switch: enabled
1: vlan1: 1 2 3 5t
2: vlan2: 0 5
603: vlan603: 0t 5t
630: vlan630: 0t 4
Thanks a lot.
