[question] Is there a way to adjust voltage setting
Mystiqz
I'm currently using 3.0.0.4.270.26 (Merlin build). Is there a way to lower the voltage setting on the router to decrease the range of the signal? I only need about 10-15 foot range.
Thanks in advance.
Thanks in advance.
Not that I know. You could reduce the output power, but it caps at about 20 or 40 mW minimum if I recall.
Wifi wasn't really designed to be so short-ranged (unlike Bluetooth).
