[Question] kernel: potentially unexpected fatal signal 11 (?!)
sentinelvdx
Hi @RMerlin,
Since 386.4 Final I've started seeing this on my logs. Should I worry?
Jan 10 18:47:07 kernel: potentially unexpected fatal signal 11.
Jan 10 18:47:07 kernel: CPU: 1 PID: 487 Comm: dcd Tainted: P           O    4.1.52 #2
Jan 10 18:47:07 kernel: Hardware name: 94908REF (DT)
Jan 10 18:47:07 kernel: task: ffffffc02fc66b00 ti: ffffffc022ae4000 task.ti: ffffffc022ae4000
Jan 10 18:47:07 kernel: PC is at 0xf735039c
Jan 10 18:47:07 kernel: LR is at 0x1dd58
Jan 10 18:47:07 kernel: pc : [<00000000f735039c>] lr : [<000000000001dd58>] pstate: 600f0010
Jan 10 18:47:07 kernel: sp : 00000000ffa3c548
Jan 10 18:47:07 kernel: x12: 00000000000a2050
Jan 10 18:47:07 kernel: x11: 00000000f65ff024 x10: 00000000000a23c4
Jan 10 18:47:07 kernel: x9 : 00000000f65ff93c x8 : 00000000000a287c
Jan 10 18:47:07 kernel: x7 : 00000000f65ff974 x6 : 00000000000a2876
Jan 10 18:47:07 kernel: x5 : 0000000000000000 x4 : 00000000f65ff920
Jan 10 18:47:07 kernel: x3 : 0000000000000000 x2 : 00000000ffa3c524
Jan 10 18:47:07 kernel: x1 : 000000000007d652 x0 : 0000000000000000
Jan 10 18:56:32 kernel: potentially unexpected fatal signal 11.
Jan 10 18:56:32 kernel: CPU: 1 PID: 4000 Comm: dcd Tainted: P           O    4.1.52 #2
Jan 10 18:56:32 kernel: Hardware name: 94908REF (DT)
Jan 10 18:56:32 kernel: task: ffffffc03253c040 ti: ffffffc02256c000 task.ti: ffffffc02256c000
Jan 10 18:56:32 kernel: PC is at 0xf70ff39c
Jan 10 18:56:32 kernel: LR is at 0x1dd58
Jan 10 18:56:32 kernel: pc : [<00000000f70ff39c>] lr : [<000000000001dd58>] pstate: 600f0010
Jan 10 18:56:32 kernel: sp : 00000000ffd97c58
Jan 10 18:56:32 kernel: x12: 00000000000a2050
Jan 10 18:56:32 kernel: x11: 00000000f63ff024 x10: 00000000000a23c4
Jan 10 18:56:32 kernel: x9 : 00000000f63ff93c x8 : 00000000000a287c
Jan 10 18:56:32 kernel: x7 : 00000000f63ff974 x6 : 00000000000a2876
Jan 10 18:56:32 kernel: x5 : 0000000000000000 x4 : 00000000f63ff920
Jan 10 18:56:32 kernel: x3 : 0000000000000000 x2 : 00000000ffd97c34
Jan 10 18:56:32 kernel: x1 : 000000000007d652 x0 : 0000000000000000
Jan 10 19:06:58 kernel: potentially unexpected fatal signal 11.
Jan 10 19:06:58 kernel: CPU: 1 PID: 6886 Comm: dcd Tainted: P           O    4.1.52 #2
Jan 10 19:06:58 kernel: Hardware name: 94908REF (DT)
Jan 10 19:06:58 kernel: task: ffffffc032bdab00 ti: ffffffc02926c000 task.ti: ffffffc02926c000
Jan 10 19:06:58 kernel: PC is at 0xf748939c
Jan 10 19:06:58 kernel: LR is at 0x1dd58
Jan 10 19:06:58 kernel: pc : [<00000000f748939c>] lr : [<000000000001dd58>] pstate: 600f0010
Jan 10 19:06:58 kernel: sp : 00000000ff9e84a8
Jan 10 19:06:58 kernel: x12: 00000000000a2050
Jan 10 19:06:58 kernel: x11: 00000000f67ff024 x10: 00000000000a23c4
Jan 10 19:06:58 kernel: x9 : 00000000f67ff93c x8 : 00000000000a287c
Jan 10 19:06:58 kernel: x7 : 00000000f67ff974 x6 : 00000000000a2876
Jan 10 19:06:58 kernel: x5 : 0000000000000000 x4 : 00000000f67ff920
Jan 10 19:06:58 kernel: x3 : 0000000000000000 x2 : 00000000ff9e8484
Jan 10 19:06:58 kernel: x1 : 000000000007d652 x0 : 0000000000000000
The frequently reported "dcd crash". Often caused by an incompatibility with Diversion's Pixelserv. Worried?, that's down to you.
Same here on my AX88U 386.4 , I have never seen this before in logs. I have been using the exact same amtm scripts and settings on older Merlin versions on the same AX88U, but this is the first time I notice this.
Jan 18 22:03:58 RT-AX88U kernel ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=21505
Jan 18 22:04:48 RT-AX88U kernel potentially unexpected fatal signal 11.
Jan 18 22:04:48 RT-AX88U kernel CPU: 1 PID: 5051 Comm: dcd Tainted: P O 4.1.51 #2
Jan 18 22:04:48 RT-AX88U kernel Hardware name: Broadcom-v8A (DT)
Jan 18 22:04:48 RT-AX88U kernel task: ffffffc024360040 ti: ffffffc028208000 task.ti: ffffffc028208000
Jan 18 22:04:48 RT-AX88U kernel PC is at 0xf6f1d39c
Jan 18 22:04:48 RT-AX88U kernel LR is at 0x1dd14
Jan 18 22:04:48 RT-AX88U kernel pc : [<00000000f6f1d39c>] lr : [<000000000001dd14>] pstate: 600f0010
Jan 18 22:04:48 RT-AX88U kernel sp : 00000000ffb1af58
Jan 18 22:04:48 RT-AX88U kernel x12: 00000000000a2050
Jan 18 22:04:48 RT-AX88U kernel x11: 00000000f61ff024 x10: 00000000000a23c4
Jan 18 22:04:48 RT-AX88U kernel x9 : 00000000f61ff814 x8 : 00000000000a287c
Jan 18 22:04:48 RT-AX88U kernel x7 : 00000000f61ff84c x6 : 00000000000a2876
Jan 18 22:04:48 RT-AX88U kernel x5 : 0000000000000000 x4 : 00000000f61ff7f8
Jan 18 22:04:48 RT-AX88U kernel x3 : 0000000000000000 x2 : 00000000ffb1af34
Jan 18 22:04:48 RT-AX88U kernel x1 : 000000000007d75a x0 : 0000000000000000
Jan 18 22:05:47 RT-AX88U kernel ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=22529
Jan 18 22:27:46 RT-AX88U kernel potentially unexpected fatal signal 11.
Jan 18 22:27:46 RT-AX88U kernel CPU: 1 PID: 6156 Comm: dcd Tainted: P O 4.1.51 #2
Jan 18 22:27:46 RT-AX88U kernel Hardware name: Broadcom-v8A (DT)
Jan 18 22:27:46 RT-AX88U kernel task: ffffffc02c616bc0 ti: ffffffc023f10000 task.ti: ffffffc023f10000
Jan 18 22:27:46 RT-AX88U kernel PC is at 0xf731a39c
Jan 18 22:27:46 RT-AX88U kernel LR is at 0x1dd14
Jan 18 22:27:46 RT-AX88U kernel pc : [<00000000f731a39c>] lr : [<000000000001dd14>] pstate: 600f0010
Jan 18 22:27:46 RT-AX88U kernel sp : 00000000ff889e38
Jan 18 22:27:46 RT-AX88U kernel x12: 00000000000a2050
Jan 18 22:27:46 RT-AX88U kernel x11: 00000000f65ff024 x10: 00000000000a23c4
Jan 18 22:27:46 RT-AX88U kernel x9 : 00000000f65ff814 x8 : 00000000000a287c
Jan 18 22:27:46 RT-AX88U kernel x7 : 00000000f65ff84c x6 : 00000000000a2876
Jan 18 22:27:46 RT-AX88U kernel x5 : 0000000000000000 x4 : 00000000f65ff7f8
Jan 18 22:27:46 RT-AX88U kernel x3 : 0000000000000000 x2 : 00000000ff889e14
Jan 18 22:27:46 RT-AX88U kernel x1 : 000000000007d75a x0 : 0000000000000000
dcd process crash, caused by pixelserv-tls. There's been quite a few posts about this on the forums, the only option right now is to uninstall pixelserv-tls.
Thank you very much. I found an option which disables pixelserv, so I disabled it, hoping that it might be enough. I will keep an eye on the logs to see the result.
FWIW, I also had these dcd process crashes after a dirty upgrade (386.3_2 to 386.4). I was using diversion + pixelserv and all Trend MIcro disabled. There were no dcd errors before the upgrade. I then did a full WPS reset and manual rebuild, still with diversion + pixelserv and all Trend MIcro disabled, and the dcd crashes have gone.
I didn't have the time to do a full reset and reconfigure everything, but probably do it during the weekend.
Same dcd issue, diversion lite so no pixelserv, but disabling diversion makes it go away.
Sep 16 21:06:27 kernel: potentially unexpected fatal signal 7.
Sep 16 21:06:27 kernel: CPU: 1 PID: 25532 Comm: PS_pod Tainted: P        W  O    4.1.52 #2
Sep 16 21:06:27 kernel: Hardware name: Broadcom-v8A (DT)
Sep 16 21:06:27 kernel: task: ffffffc015066040 ti: ffffffc0107a8000 task.ti: ffffffc0107a8000
Sep 16 21:06:27 kernel: PC is at 0xf6ae0330
Sep 16 21:06:27 kernel: LR is at 0xf6ae0518
Sep 16 21:06:27 kernel: pc : [<00000000f6ae0330>] lr : [<00000000f6ae0518>] pstate: a0010010
Sep 16 21:06:27 kernel: sp : 00000000ff879860
Sep 16 21:06:27 kernel: x12: 00000000f73ae390
Sep 16 21:06:27 kernel: x11: 00000000ff87989c x10: 00000000ff879874
Sep 16 21:06:27 kernel: x9 : 00000000f6b81000 x8 : 0000000000000000
Sep 16 21:06:27 kernel: x7 : 0000000000000078 x6 : 0000000000000001
Sep 16 21:06:27 kernel: x5 : 00000000ff879860 x4 : 0000000000000000
Sep 16 21:06:27 kernel: x3 : 00000000f73b6058 x2 : 0000000000000000
Sep 16 21:06:27 kernel: x1 : 000000000000000c x0 : 0000000000000000
The same, but fatal signal 7, and i only have vnstat addon.
Different error. Your process crash is PS_pod not dcd.
@ColinTaylor Thanks! But what does "PS_pod" do?
UPDATE: did power off/on - fatal signal entries disappeared... Now i am puzzled - router is not that old...
