SandmanXX
I haven't seen my question answered yet anywhere else here.
I have a GTAX11000 as the main router, a RT-AX3000 and a RTax88U as 2 mesh nodes. I have found that the ax3000 is transmitting 2 different ssid (2.4g and 5g) than the main router, and not passworded. Wifi analyzer shows the ssid, but I can not connect to them normally on the phone.
How do I access the node setting page? And if I can do that, should I rename the SSID to the main router's SSID? I do want the same network for handing off to devices closer to whichever node.
They are all 3 wired together, ethernet backhaul,
Thanks.
Thanks.
