In the process of learning Cisco CCNA/CCENT. I got one 2950 cisco switch hooked up via console/serial to my desktop PC.
I just configured and setup a VLAN Ip Address. What would be the best method to connect to my switch remotely? Would I connect my 1721 router that I have to it, then connect my 1721 to my Asus AC87U Wifi router I use at home? This CBTNugget has an example where the person has two network ports on his home pc, which I do not. So I would have to run it to my router.
Or would I skip the cisco router, and just plug into my AC87R, and find somewhere on the router to setup an static ip that I have assigned to my switch?
Also, if I turn the switch off, do I lose all config on the switch? Thanks
