Patrick9876
For years I've used separate SSIDs for my 2.4GHz and 5GHz WiFi connections (and therefore didn't use Smart Connect) but I'm questioning those decisions. I've seen pro and con discussions about Smart Connect but have seen almost nobody recommend different SSIDs on the 2.54 and 5 GHz bands. I would like to know if I should change.
The problem: I have 3 laptops and a tablet (among other devices) using my wireless network. The have network profile definitions for both the 2,4 and 5 GHz SSID's and prioritise the 5 over 2.4. Very occasionally one will pick 2.4. (I've never determined why.) Each of these computers takes backups to a NAS on the LAN. The backup software is quite sensitive to network outages and will kill (and not restart) a backup if I tell the computer (running Windows) to switch to a different wireless profile, plug in an Ethernet cable, etc. I don't know enough about Smart Connect to know what happens if it steers a connection to a different band but I assume that switch would also kill a backup. I think that means I should avoid Smart Connect, but I'm willing to be convinced otherwise.
Regarding using the same SSID for both bands, I'm not sure how I would detect and handle situation where the computers have needlessly selected wrong band. Right now it's easy for me to see which band is used by looking at the connection SSID, and it's easy to tell Windows to switch to another SSID (if I'm willing to deal with a brief outage). It would be more difficult to identify use of the wrong band, and there would be no way to influence selection of the 5GHz band.
How does an ASUS router, running Merlin, pick which band to use when both bands use the same SSID and Smart Connect is not enabled? does is pick 5 over 2.4 if the connecting device supports it?
