Considering the RT-AX86u Pro (Because of it's form factor)...
I have a couple of questions...
I know originally WIREGUARD on the new AX (388 Firmware) routers had
it's hardware acceleration disabled which limited throughput on Wireguard to around 350Mbps...But
I believe I read that that is no longer the case and the hardware acceleration on WIREGUARD is now
enabled so throughput speed on Wireguard is much higher? Can someone please confirm that.
I would be using the Wireguard Client.
Also in Merlin Firmware for the RT-AX86u Pro is SMB 1.0 and 2.0 still an option in the settings (Like it was for the RT-AC86u)?
TIA
TIA
