Hello,
I have two ASUS RT-AX58U with AiMesh in my home. They are working stabile, but I have 1-2 questions:
-Guest network: I know, that with AiMesh, the only option is, that the Guest network is only on the main Router. Do we have any other options?
-How can I view the processor and memory usage for the AiMesh node - I mean from the Router app or Web UI?
-Are the WiFi settings synchronized to all of the AiMesh nodes (for example AX MU-MIMO)? I guess, that the settings are "standard" on the nodes, because I have different speeds from the QNAP TS-230 NAS (cable, Gigabit, AiMesh router) on the main router and on the node. Can I "switch on" the settings sync to the nodes, or should I set the settings manual with nvram commands?
Thank you for your help,
Csaba
Csaba
