Quick Question about Merlin FW 380.65_4
pinkfloyd1173
I have a quick question about this new fw that I installed on my RT-AC3100.
I cannot see the temps on my wifi networks, is there a option that I did not enable??? On past fw's I never had this issue.
Thanks in advance.
Thank you,
I did a factory reset when I installed new FW. Just bought the router again yesterday?
Werid.
No quantity of hard resets with manual reconfiguration will fix this with current firmware. The problem is reportedly that the current GPL wireless driver lacks support needed to interrogate temperatures on the newer Broadcom chip, which is used in hardware rev A5 of AC-3100 / RT-N88U. The wl command returns "unsupported" when asked for radio temps, thus the web interface shows "disabled".
See also this answer from Eric: RT-AC88U disabled radio temperatures
I've hard reset (both via red reset button, and via power-on with wps button), and manually reconfigured my RT-N88U multiple times -- radios still show "disabled" with 380-65. After a hard reset, even before any reconfiguration, the radio temps both show "disabled". It's because the current wireless driver can't read them from A5 hardware revision.
Hopefully it will be corrected in a future GPL release.
I see the same thing on my 88u and only the cpu temp is present.
