Quick way to copy traffic routing rules from one ovpn client config to another
Ian Macdonald
I have an AC-86U and an OpenVPN client config (client 3) with 20+ tunnel routes. Now I want to create a second client config (client 5) that uses the same set of routes.
I really don't want to type all of those routes into the GUI a second time, so I thought I'd be clever and do it on the command line. After some poking around, I came up with the following:
for i in '' 1 2 3 4 5; do
  nvram set 'vpn_client_unit=3'
  foo="$(nvram get vpn_client_clientlist$i)"
  nvram set 'vpn_client_unit=5'
  nvram set "vpn_client_clientlist$i=$foo"
done
Unfortunately, setting vpn_client_unit isn't enough to switch to the right client config for reading or writing. Can anyone tell me what I'm missing here?
Additionally, if I manually set vpn_client_clientlist and vpn_client_clientlist[12345] to the right values, they don't stick and constantly revert to the old (blank) values. So I'm evidently missing something there, too. I thought nvram commit might be the answer here, but that doesn't help, either.
I'm not accustomed to reading and writing NVRAM on the command line, so I'm probably making a beginner's error somewhere in my expectations.
done
The NVRAM variable names are wrong
e.g. try
foo=$(nvram get vpn_client${i}_clientlist)
nvram commit
P.S. Not sure if Base64 encoding is required for these fields on AC86U?...but you will soon spot it! ;)
e.g. try
nvram commit
Ha! I knew it would be something simple. Thank you very much.
So, the much simpler working solution is just this:
  nvram set "vpn_client5_clientlist$i=$(nvram get vpn_client3_clientlist$i)"
done
The commit isn't even needed.
I thought of the Base64 issue myself, but reasoned that the output of one config would probably work as the input of another, assuming that no implicit conversion takes place anywhere. At it turns out, though, Base64 isn't used at all.
Interestingly, the set of vpn_client_clientlist variables, i.e. with no client digit following the vpn_client portion, do also exist as variables, but setting them doesn't do anything. They appear to simply be duplicates of the variables belonging to whichever client config is currently selected in the GUI.
