pidgeynerd
Hi everyone, I've been a long time lurker but decided to finally jump in and seek some advice.
Some background - I'm a Cloud Architect at Microsoft and specialize in Software Defined Networking. My spouse is also a Cloud Architect and works for AWS so discussions are fun and competitive. We are very technical and always looking for some cool project to work on. Complexity is more of an interest than a turn off. We spend all our time working from home with our jobs so our home network is essential. However, our current setup is fairly basic - I run a Linksys EA9300 + a RasberryPi for PiHole w/DHCP + Unbound for DNS. The router is very lackluster when it comes to features (no VPN, Firewall, Custom Routes etc.), but it does a surprisingly decent job of covering a 7000 sqft home and 40+ devices (Gaming Desktops, Laptops, Phones, Tablets, Game Consoles, TV's, IoT Devices etc.) Internet speed is about 400Mbps down but will look to upgrade to 1Gbps in the near future. If my current router supported a 3rd party firmware like DD-WRT, I would likely be able to solve a lot of my problems.
Some things I need to be able to do with a new router are the following:
This brings me to routers and budget. I'm not very strong on the hardware side of things. So while a professional grade router would be cool, I don't how much more value I would get from a Cisco Meraki MR56 vs an offering from MicroTik for example. I'd prefer to just have a Wireless Router instead of an Access Point. However, hearing pros vs cons would be great.
https://www.amazon.com/dp/B087CBCX4V/?tag=snbforums-20
https://www.amazon.com/dp/B07QMNNVG8/?tag=snbforums-20
How do these compare versus a consumer grade Asus router?
https://www.amazon.com/dp/B07HM6KJN8/?tag=snbforums-20
My budget is fairly wide so anything up to and around $1000 is fair game. I care about getting a rich feature set with great reliability and performance.
Please share your thoughts and recommendations.
- Support VPN with the ability to route certain clients out over VPN or directly to the internet. Example: Route certain Laptops over VPN all the time, but have others route directly to the Internet. Doing this based on MAC/Static IP is fine but doing it based on destination FQDN would be a plus. So if going to X site, route over VPN. If going to Netflix.com, route directly to Internet.
- Support to have the router perform DHCP while using PiHole + Unbound for DNS. My current router must offload DHCP if you want to use something else for DNS too.
- Support to route/redirect all traffic based on port/protocol. Example: Certain Android devices hard code 8.8.8.8 for DNS no matter what. Changing the DNS servers for the WiFi network or turning off Private DNS on Android doesn't fix this. However, blocking/redirecting all DNS/Port 53 traffic to PiHole at the router may fix this issue.
- All of the typical must haves would apply - Multi-Band 5GHz, WIFI 6 support (maybe), MU-MIMO etc.
