AntonK
I just updated my firmware to the latest version, and note that the instructions from NETGEAR state:
Just prior to updating, I had saved my router's settings via the interface's Administration -- Backup Settings -- Save a copy of current settings tool. After the upgrade, I reset to factory default as directed above, and then restored the settings I had saved, so as not to have to rebuild my router's settings from scratch. Is that an okay way to perform an upgrade from one NETGEAR firmware version to the next? All seems to be working normally.
Thanks for any advice.
Anton
"Please remember to do factory default after firmware upgrade. Enter "Backup Settings" in the web GUI and click "Erase" button of "Revert to factory default settings". "
Anton
