Musky-Hunter
I was about to purchase a R7000 to replace my aging Dir-655 until I read a review about QoS that has me concerned it may not be right for me. Can anyone comment on if what was said is still accurate based on current firmware and if it will be an impact on my setup?
The reviewer said the QoS is preconfigured to prioritize devices and it may make devices low priority that I will want high priority but there is no manual override. Furthermore, apparently it does not have ability to recognize and prioritize VoIP.
My setup is
Mediacom cable internet 50mbs
Direct wired Xbox One, Directv, AppleTv, WinPC, Ooma VoIP
Wireless Epson printer, Xbox360, 3 phones, 2 PC's, 2 iPads, up to 5+ guests
Based on above, should I concern myself with prioritization? Is the Asus AC68U better suited for me? I am not very network savvy so if the GUI is not very intuitive I will likely fail to take advantage of highly complex config options.
Ps I will be adding Ooma this week and will need more than the 4 ports on my router. Can anyone recommend how to support the additional connections? Switch? Should I follow Ooma recommended setup and put the device between the modem and the router or hang it off the router or switch?
Thank you in advance.
My setup is
