Killhippie
Ok bit of a silly question, on the R7800 I have, and others I have seen the rear two aerials lean forward at an angle as the connection to the router is not horizontal, so are the two side aerials meant to lean forward to match this angle, or are they meant to be vertical? Or does it make no difference whatsoever? Just wondered. Ok I'll go hide now
