Hi there, sorry for my lack of knowledge in advance. I'm a bit inexperienced mucking around in linux but I'm hopeful someone here will be able to point me in the right direction.
I'm trying to determine the cause behind occasional radio outages/reboots on my r7800. When I log in via telnet I see /var is symlinked to /tmp and all the logs get cleared after reboot. Is there a way to disable the clearing of /tmp/log/message and /tmp/log/log-message so that I can properly investigate this issue?
Running voxel V1.0.2.74.1SF, though I was experiencing this issue on stock since I updated fw (I forget which version I was on originally). Let me know if there's any other information I should include in case it would be helpful.
Thanks!
Thanks!
