joshhighley
My R7800 with Voxel is my main router. I have a second router running a wireguard/vpn client. For certain devices, I want to use this second router as a gateway instead of the default main router and while still connecting via wireless to the main router.
Is there any way in Voxel to assign a different gateway to certain IPs, which I can statically assign to those devices? I can't set the gateway manually on the devices (Rokus, etc) so need DHCP to assign it. I don't see a way to do it with udhcpd but I'm not finding much info. Some info suggests entware dnsmasq may be able to do this but I'm hesitant to change my main router this way -- I'd probably just connect directly to the wireless of the second router.
