Hi All,
I was pointed here from another forum. I've got FiOS Gigabit service and I can get solid numbers for speed checks when I connect my desktop to the FiOS Gateway. When I connect to the R7960P, however, my ethernet speed drops to ~300-400 Mbps. Wifi speeds are in the 90-300 Mbps range, depending on distance from the router, as expected.
I'm assuming I have a feature turned on or off, which is causing this issue. I have the router in a DMZ on the FiOS Gateway, and both devices sit right next to each other on my desk. All related patch/connection cables are CAT 5e or better, and new. Firmware is up to date. Could some weirdness with QoS be causing this issue? Anything else I should check?
I'm debating doing a reset on the router tonight, to see if that solves the problem by at least proving that the baseline config doesn't have this issue.
