Raw hardware spec numbers between GT-AXE16000 and ET12
mower8739
I've read all the reviews, searched all the sites, but finding clearcut plain information about raw specs of these things is actually kind of hard. I'm basically wondering of the spec differences between these two.
CPU, memory antenna power, all of it.
If you had a single GT-AXE16000 and a single ET12 in the same environment, which one would have better range, which on would support more clients, etc, etc.
The same CPU BCM4912, the same radios BCM6715, for power amp and antenna gain information look at FCC certification pages. May be some differences in range because of the design, but client support is expected to be the same. Expect shorter 6GHz band range in both cases compared to 5GHz band.
