Hi All,
I recently got a used RBR50 device and its in constant green light mode. Nothing helps anb its not changing to anything no matter how hard i tried (resets, tftp mode and etc.
I opened it up and connected serial console. Here is what im getting. AM i correct thinking that it is physical bad flash memory chip and there is nothing to be done here? Can you please take a look and advise? It stops in console and nothing happens.
Thank you in advance!
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00110
S - IMAGE_VARIANT_STRING=DAAAANAZA
S - OEM_IMAGE_VERSION_STRING=CRM
S - Boot Config, 0x00000023
S - Reset status Config, 0x00000000
S - Core 0 Frequency, 0 MHz
B - 262 - PBL, Start
B - 1342 - bootable_media_detect_entry, Start
B - 65343 - bootable_media_detect_success, Start
B - 65357 - elf_loader_entry, Start
B - 67786 - auth_hash_seg_entry, Start
B - 69951 - auth_hash_seg_exit, Start
B - 105221 - elf_segs_hash_verify_entry, Start
B - 220274 - PBL, End
B - 220299 - SBL1, Start
B - 312478 - pm_device_init, Start
D - 9 - pm_device_init, Delta
B - 313993 - boot_flash_init, Start
D - 28053 - boot_flash_init, Delta
B - 346400 - boot_config_data_table_init, Start
D - 2961 - boot_config_data_table_init, Delta - (419 Bytes)
B - 354060 - clock_init, Start
D - 7540 - clock_init, Delta
B - 365479 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:0,Subtype:1
B - 368885 - sbl1_ddr_set_params, Start
B - 373978 - cpr_init, Start
D - 2 - cpr_init, Delta
B - 378361 - Pre_DDR_clock_init, Start
D - 4 - Pre_DDR_clock_init, Delta
D - 13171 - sbl1_ddr_set_params, Delta
B - 391656 - pm_driver_init, Start
D - 2 - pm_driver_init, Delta
B - 462967 - sbl1_wait_for_ddr_training, Start
D - 27 - sbl1_wait_for_ddr_training, Delta
B - 479334 - Image Load, Start
D - 19591 - QSEE Image Loaded, Delta - (262104 Bytes)
B - 499352 - Image Load, Start
D - 899 - SEC Image Loaded, Delta - (0 Bytes)
B - 509202 - Image Load, Start
D - 12424 - APPSBL Image Loaded, Delta - (416039 Bytes)
B - 522052 - QSEE Execution, Start
D - 60 - QSEE Execution, Delta
B - 528232 - SBL1, End
D - 310045 - SBL1, Delta
S - Flash Throughput, 21924 KB/s (678738 Bytes, 30958 us)
S - DDR Frequency, 672 MHz
U-Boot 2012.07 [Barrier Breaker unknown,unknown] (Jan 04 2017 - 13:54:09)
U-boot dni1 V1.4 for DNI HW ID: 29765352; NOR flash 32MB; EMMC flash 4000MB; RAM 512MB
smem ram ptable found: ver: 1 len: 3
DRAM: 512 MiB
machid : 0x8010001
NAND: ID = 0
Vendor = 0
Device = 0
Nand Flash error. Status = 64
ONFI Read id cmd failed
ONFI probe failed
SF NAND unsupported id:ff:ff:ff:ffSF: Unsupported manufacturer ff
ipq_spi: SPI Flash not found (bus/cs/speed/mode) = (0/0/48000000/0)
0 MiB
MMC: qca_mmc: 0
*** Warning - bad CRC, using default environment
PCI0 Link Intialized
In: serial
Out: serial
Err: serial
Valid chip addresses:
