Hi all,
Newbie here, hoping to get some advice from more experienced users. I'm looking to re-visit the setup of my home network.
Some facts from the attached diagram:
I'd like to get AC coverage in my house, and the 2nd router has a better position in my house for this. I'm looking to replace it with an ASUS RT-AC66U. Would this be feasible, since the main router isn't the more powerful router?
Also, since the main router is in the basement, does anyone have a good suggestion for a wired router that will run DD-WRT?
Any help you would appreciated!
- We have FiOS, but I don't use the FiOS router (Actiontec) for anything. WiFi is turned off, PPTP ports are forwarded, and it has one static lease for my e2000
- The e2000 is running DD-WRT and is my DHCP and PPTP VPN server
- I have a wired connection to another e2000 running DD-WRT that is a DHCP forwarder
- Both routers broadcast our home WiFi SSID
- The main router has a bridge to a virtual interface and broadcasts a guest SSID
