When I was using my AC86U I was having problems with the GUI reboot scheduler. I didn't have any problems with the amtm scheduler though. I didn't have any problems using the GUI scheduler with my AX88U.I'm wondering which is the better reboot schedule to use the one in the GUI or amtm based reboot schedule.
I'm just curious after seeing the option, I've also been hearing about a service reboot, rather than a full one, not sure what this is about.
service reboot
I was thinking about using the amtm reboot schedule, I'm even half tempted to just factory reset the router to see if that helps.There was an issue at some time in the past and RMerlin made changes to Asuswrt-Merlin and the lonely coder did the same with amtm to both use the full path to call reboot.
I've tired to search for that conversation from a couple years back, but no luck. I think it went back and forth between two or three threads.Code:service reboot
If I want to reboot from the CLI, I use the "service reboot" instead of just "reboot" and had no issues for months, maybe years.
You could also set up a cron job to do it, I used to do that until the issue of the AC86U hanging on reboot (mine has not for months, knock wood)I was thinking about using the amtm reboot schedule, I'm even half tempted to just factory reset the router to see if that helps.
It's just that I noticed that the reboot doesn't seem to be executing property, it's like there is still long entries I half suspect my time sync is our of whack an I need to adjust it.
3 3 * * * service reboot #scheduled_reboot#
4 */8 * * * service restart_httpd #restart_httpd#
We use essential cookies to make this site work, and optional cookies to enhance your experience.
