Recent TP-Link Issues
coxhaus
Part of the Furniture
Here are couple of things you may want to be aware of. Hopefully TP-Link releases quick firmware fixes.
tp-link -- archer_c90_firmwareThis vulnerability allows remote attackers to execute arbitrary code on affected installations of TP-Link Archer C90 1.0.6 Build 20200114 rel.73164(5553) routers. Authentication is not required to exploit this vulnerability. The specific flaw exists within the handling of DNS responses. A crafted DNS message can trigger an overflow of a fixed-length, stack-based buffer. An attacker can leverage this vulnerability to execute code in the context of root. Was ZDI-CAN-14655.2022-01-2110CVE-2021-35003
MISC
tp-link -- tl-wa1201_firmwareThis vulnerability allows remote attackers to execute arbitrary code on affected installations of TP-Link TL-WA1201 1.0.1 Build 20200709 rel.66244(5553) wireless access points. Authentication is not required to exploit this vulnerability. The specific flaw exists within the handling of DNS responses. A crafted DNS message can trigger an overflow of a fixed-length, stack-based buffer. An attacker can leverage this vulnerability to execute code in the context of root. Was ZDI-CAN-14656.2022-01-2110CVE-2021-35004
