Recommend a replacement for an eero gen 1 setup
geekmiki
I have a 3 eero gen1 setup that has been working great for 7 years, but it's n longer supported and one of the APs is having issues lately.
I am looking either for routers that can be setup as a mesh network (ie. Asus AiMesh, TP Link OneMesh...) or a 3 AP out of the box mesh system. Ideally, this would be something that I would keep at least 5-6 years and that costs under 500 $/€.
I'll have 2 of the 3 APs connected with ethernet and it'll be used in a typical home environment with 30-40 devices and a 750/350 Mbps cable connection (that might be upgraded to 1Gbps in the near future). Wifi 6E would be nice, 7 is definitely not a must have at this stage.
I am located in Norway, so a newer eero setup is unfortunately not possible (not sold locally).
Any recommendations?
Can you get eero from one of the other nearby countries where Amazon has a presence ? Or will Amazon ship to Norway ?
TP-Link Omada, but it has a bit of a learning curve. TP-Link DECO may be close to what you have.
