I've just recived and tested screenbeam 2.5 MoCA adapters by connecting them using a coaxial cable and verified that the adapters do work. Currently, I have this setup which was leftover from my previous cable modem setup. However, now I currently have fiber FTTH and no longer use Coaxial setup. After hooking up the tested screenbeam MoCA 2.5 adapters both are using the latest firmware: 1.17.5 and HW: AM1 version.
My setup is as follows:
Coaxial In from external demarcation ----> MVRAM502B 4 port +1 VOIP https://www.antronix.com/datasheet?id=ds1195-ar-a01_mvram502b.pdf MoCA Residential Amplifier - 4 Port
1. Can someone please recommend me a reliable 4 port MoCA 2.5 compatible splinter?
2. What's the difference between active and passive MoCA splitters ?
Thank you in advance.
