HairyA00
I noticed that the default blocklist is StevenBlack's, which is great. But I suggest removing the "fakenews" variant. "fakenews" is a very political, biased category of domains to block, and no one will ever agree on which domains should and shouldn't be blocked. I noticed some websites on there that do not belong under the category of "fakenews", but I also don't feel like arguing with anyone. So I removed the Standard list in favor of the ones I mention below.
The standard should remove ads, malware, etc objectively, not censor the Internet subjectively.
The "standard" blocklists should be something like this:
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
http://sysctl.org/cameleon/hosts
https://hosts-file.net/ad_servers.txt
https://mirror1.malwaredomains.com/files/domains.hosts
None of those are 'subjective' lists, the likelihood of whitelisting is almost zero, and it stays out of politics.
Just my two cents; I have been running sinkholes for quite some time now, and I hardly ever whitelist or blacklist anything using those aforementioned lists. Worth noting though is that I do use a hosted whitelist:
https://raw.githubusercontent.com/anudeepND/whitelist/master/domains/whitelist.txt
In Diversion:
b > 1 > 1 > 2
In Diversion:
b > 1 > 1 > 2
