Thanks in advance to all who take the time to reply/post on this thread.
I am reconfiguring and rebuilding my legacy network, but based on my existing equipment and requirements (and reading lots of SNB articles/forum posts), I have decided to rebuild from scratch for the most part. Request feedback on my network configuration and proposed items for purchase as follows.
My network requirements:
Item #1: Primary router and wireless AP (downstairs/media center location)
--WAN interface with Scientific Atlanta DPC-2203 cable modem (10/100 Mbps port) at that location
--LAN/router interface for a NAS (DNS-323, 10/100/1000 Mbps port), requiring LAN based management (no DNS lookup needed though).
--LAN/Router interface for 3 100/10 Mbps port clients
--Xbox 360
--Panasonic DMP-BD35 Blu-ray player
--Yamaha RX-V2700 Receiver (internet radio capable)
--Wireless AP support for upstairs wireless bridge (see Item #2 below)
Proposed product: WRT610N
--It has looks to have the best combination of Location A 5.0 GHz and location C 2.4GHz performance
--I already have a cooling fan in my media center that I can use to mitigate potential heat issues of the WRT610N
--Seems like latest firmware has improved initial stability issues
Products also considered:
--WNDR3700--runs cooler, might be more stable, but more expensive;
--DIR-825—better performance for my A/C locations, but
Item #2: Wireless bridge (upstairs location, ~Location C equivalent (about 25’ away, through wood/carpet floor, no walls))
--Wireless bridge to downstairs router/AP
--LAN/Router interface for 2 1000 Mbps port desktop computer clients
--LAN/Router interface for a USB print server.
--Based on location, 5.0 GHz is not likely useful/needed
Proposed product: WET610N (+ existing DI-724 GU router which provides 4 gigabit ports and a USB print server)—cheap, good performance (would deactivate the DI-724’s 802.11g AP of course)
Other products considered:
--DIR-655—would have been perfect, but Dlink removed the bridge mode in a 2007 firmware update that can’t be reversed (…stupid and frustrating) (BTW—Tim—you might consider updating your DIR-655 A4 review to mention that the bridge mode is now gone).
--DAP-1522—comparable performance, includes ports, but more expensive and likewise doesn’t eliminate need for using my DI-724GU as a print server; don’t want to reward Dlink for removing the bridge functionality from the DIR-655….
Item #3: Laptop adapter
Laptop is typically used 7-10’ away from downstairs router within unobstructed line of sight (~Location A equivalent).
Both USB and PCMCIA ports are available.
Proposed product: WPC600N
Again, request thoughts and feedback on trying to make a good purchase....
--Xbox 360
