Jan 8 16:33:14 rc_service: httpd 498:notify_rc start_vpnclient1
Jan 8 16:33:14 kernel: tun: Universal TUN/TAP device driver, 1.6
Jan 8 16:33:14 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jan 8 16:33:14 openvpn[3054]: OpenVPN 2.3.7 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Jul 16 2015
Jan 8 16:33:14 openvpn[3054]: library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
Jan 8 16:33:14 openvpn[3055]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 8 16:33:14 openvpn[3055]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Jan 8 16:33:14 openvpn[3055]: UDPv4 link local: [undef]
Jan 8 16:33:14 openvpn[3055]: UDPv4 link remote: [AF_INET]172.98.67.55:1194
Jan 8 16:33:14 openvpn[3055]: TLS: Initial packet from [AF_INET]172.98.67.55:1194, sid=b43b5da2 a4c0a388
Jan 8 16:33:14 openvpn[3055]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Jan 8 16:33:14 openvpn[3055]: VERIFY OK: depth=1, C=US, ST=OH, L=Columbus, O=Private Internet Access, CN=Private Internet Access CA, emailAddress=secure@privateinternetaccess.com
Jan 8 16:33:14 openvpn[3055]: Validating certificate key usage
Jan 8 16:33:14 openvpn[3055]: ++ Certificate has key usage 00a0, expects 00a0
Jan 8 16:33:14 openvpn[3055]: VERIFY KU OK
Jan 8 16:33:14 openvpn[3055]: Validating certificate extended key usage
Jan 8 16:33:14 openvpn[3055]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jan 8 16:33:14 openvpn[3055]: VERIFY EKU OK
Jan 8 16:33:14 openvpn[3055]: VERIFY OK: depth=0, C=US, ST=CA, L=LosAngeles, O=Private Internet Access, OU=Private Internet Access, CN=Private Internet Access, name=Private Internet Access, emailAddress=secure@privateinternetaccess.com
Jan 8 16:33:15 openvpn[3055]: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jan 8 16:33:15 openvpn[3055]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 8 16:33:15 openvpn[3055]: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jan 8 16:33:15 openvpn[3055]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 8 16:33:15 openvpn[3055]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Jan 8 16:33:15 openvpn[3055]: [Private Internet Access] Peer Connection Initiated with [AF_INET]172.98.67.55:1194
Jan 8 16:33:17 openvpn[3055]: SENT CONTROL [Private Internet Access]: 'PUSH_REQUEST' (status=1)
Jan 8 16:33:17 openvpn[3055]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 209.222.18.222,dhcp-option DNS 209.222.18.218,ping 10,comp-lzo no,route 10.182.1.1,topology net30,ifconfig 10.182.1.6 10.182.1.5'
Jan 8 16:33:17 openvpn[3055]: Options error: option 'redirect-gateway' cannot be used in this context ([PUSH-OPTIONS])
Jan 8 16:33:17 openvpn[3055]: Options error: option 'dhcp-option' cannot be used in this context ([PUSH-OPTIONS])
Jan 8 16:33:17 openvpn[3055]: Options error: option 'route' cannot be used in this context ([PUSH-OPTIONS])
Jan 8 16:33:17 openvpn[3055]: OPTIONS IMPORT: timers and/or timeouts modified
Jan 8 16:33:17 openvpn[3055]: OPTIONS IMPORT: LZO parms modified
Jan 8 16:33:17 openvpn[3055]: OPTIONS IMPORT: --ifconfig/up options modified
Jan 8 16:33:17 openvpn[3055]: TUN/TAP device tun11 opened
Jan 8 16:33:17 openvpn[3055]: TUN/TAP TX queue length set to 100
Jan 8 16:33:17 openvpn[3055]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Jan 8 16:33:17 openvpn[3055]: /usr/sbin/ip link set dev tun11 up mtu 1500
Jan 8 16:33:17 openvpn[3055]: /usr/sbin/ip addr add dev tun11 local 10.182.1.6 peer 10.182.1.5
Jan 8 16:33:20 openvpn-routing: Configuring policy rules for client 1
Jan 8 16:33:20 openvpn-routing: Creating VPN routing table
Jan 8 16:33:20 openvpn-routing: Removing rule 1201 from routing policy
Jan 8 16:33:20 openvpn-routing: Added 192.168.0.46 to 0.0.0.0 through VPN to routing policy
Jan 8 16:33:20 openvpn-routing: Tunnel re-established, restoring WAN access to clients
Jan 8 16:33:20 openvpn-routing: Completed routing policy configuration
Jan 8 16:33:20 custom script: Running /jffs/scripts/openvpn-event (args: )
Jan 8 16:33:20 openvpn[3055]: Initialization Sequence Completed
