Reflexive ACL.
JEofMPK
I set up AT&T fiber and put their gateway on IP passthrough. Turned off all firewall settings and opted to use the ASUS ones. One firewall setting on the gateway that I did not turn off as I was uncertain if I should is Reflexive ACL.
Per AT&T: Reflexive ACL: When IPv6 is enabled, you can enable Reflexive Access Control Lists to deny inbound IPv6 traffic unless this traffic results from returning outgoing packets (except as configured through firewall rules).
I beleive my ASUS router has he same based on the description for IP6 Firewall? Seems I should turn off the Relfexive ACL in the the AT&T Gateway?
