Hello,
I have an ASUS Ai-Mesh network consisting of a main router, RT-AC88U and an Ai-Mesh node which is an RT-AC86U wired directly to the 88U.
The house is 3 floors (Basement, Floor 1, Floor 2) and the main router, 88U, is located in the finished basement. The 86U is on Floor 2. Both items were bought in July of 2018.
Back Story
Recently, I would say the 3rd to last firmware update, I noticed that my router was freezing. I would see a strange error page similar to the following when trying to access to the router:
The only difference was the device name
When I searched for this error page, I did not find anything recent. My work-around was to just have the router automatically reboot daily around 5 AM using the reboot scheduler. I was not happy with it.
So my hunch was that perhaps through the several firmware updates since owning this router, a bug or glitch developed. So I reinitialized both the 88U and the 86U with the latest firmware.
But here's the reason for this long-winded plea for help.
Plea for Help:
The wireless on an iPad and iPhone XS on either 2.4 Ghz or 5.0 Ghz is unstable. It takes a bit for twitch.tv to even connect to a stream or load the preview of live streams. Once the stream is connected it will drop out. When browsing TikTok videos the videos takes 5 seconds to start playing and in the middle of the video, the video will start buffering. It's like there is an issue with negotiating or making an initial connection from these devices.
I tested the bandwidth on Speedtest.net and the results are great. I have rebooted my Comcast modem when this problem starts to persist.
No matter what I try, the behavior exists UNTIL...
I reboot the 88U. Once I log in, reboot the router and it comes back online everything works perfectly. Wifi is responsive. twitch.tv streams load instantly. TikTok videos load instantly. Everything is stable. Then, when I wake up in the morning, the same issue is back.
I have disabled all *Beaming* on 2.4 Ghz
I have disabled Universal beaming on 5.0 Ghz
I have disabled Airtime Fairness on both 2.4 Ghz and 5.0 Ghz
I have disabled Mu-Mimo on 5.0 Ghz
I have Ai-Protection and Traffic Analyzer enabled.
My wireless signal is excellent through-out the entire house.
I went to bed with the wireless responding perfectly and this morning I wake up and the wireless is having connection issues again. I did not have this issue before re-initializing the router.
Wired connection is not affected.
Can anyone offer any suggestions as to what this could be or how I could attempt to troubleshoot it? I am prepared to extensively troubleshoot this issue.
Thank you!
Edited: Updated the error page text to remove the incorrect device name.
Back Story
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from ...
To access the settings of ... reconnect to the wireless network and use the updated IP address and port number.
Plea for Help:
Thank you!
