Reminder: The System time zone is different from your locale setting
Tzameti35
Hi
I am having proplems getting my asus 3200 to be the correct time.
I am running the router behind my vodafone router on a DMZ. the asus router has an address of 192.168.10.4
I then run all my devivces from the asus router. i have parental shedules working and have noticed that my sons time shedule is an hour out. I went into the router Admin--system--Basic config and changed the timezone to GMT lodon. it is set to use pool.ntp.org. I have tried all sorts of combinations to rectify this but i still get the nessage
Ithe other thing is i dont know where on the router GUI you can see the time that is set.
any help would be appreciated.
regards
If you're in the UK set the system time manually, because automatic isn't always correct.
The other thing is i dont know where on the router GUI you can see the time that is set.
System Log > General Log > System Time
Ok i have tried this and is still pops up the same message. And because I can't see the time anywhere on the GUI it is impossible to ratify. so is it possible that the time could be correct but still give me the same warning?
I can see where i select gmt London and set the dst options but nowhere can i see the correct time anywhere on the router GUI. to check against my pc clock
