Log in to GUI under Admin and reset to "Factory Default Reset"Hi. I have both a AX58u and a AX56U. Both of these are runing merlin 388.1.
My question is how do i go back to stock, as flasing with latest stock firmware does not work.
Any ideas?
Is it that simple, seeing how the OP is complaining that Merlin firmware is stuck?On the AX58U you must flash 386.45898 firmware before you can upgrade to the latest. There is no need to factory reset before a firmware flash.
What I don't get is that he was already on the 388 code base and therefore was beyond the hiccup.At least on the AX58U you must install 45898 firmware before it will let you upgrade any further. Asus site says this.
*Due to core software module upgrade, if you want to upgrade to this version, please must update your router to 3.0.0.4.386.45898 first.
Welcome To SNBForums
